Can someone explain to me why, when capturing using ATI MMC using LPCM, my auido files don't have a header?
I finally figured out why my standalone player wouldn't play the audio on my DVD's. I have to have DVD-Lab demux my files, then convert the LPCM to WAV. Apparently my raw PCM files are headerless. Why is this and what does DVD-Lab insert in the WAV file (I know it's a header, but what's in the header)?
I'm just trying to understand why a raw PCM file doesn't work, while a WAV with a header does.
Raw PCM (RE:LPCM) is headerless. Apparently, your program can't handle the proper muxing of your video and LPCM audio. Your settop player should have no problem with a DVD compiled with LPCM audio.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Has anyone else had any audio issues when using ATI MMC v8.9?
I'd really like to figure this out, since it takes a lot more time to demux stuff that is suppose to already be in DVD compliant formats.
I really don't think it's my standalone, since it has been able to play everything I've thrown at it thus far. I pretty sure it's either a problem in the way the files are being captured, or the way DVD-Lab builds the VOB's.
Changing MJPEG Header Info
By codepenman in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2011, 10:42 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Program to read the DVD Header Info?
By alsnchns in forum ProgrammingReplies: 3Last Post: 4th Jul 2008, 11:51
