My quest to capture pal60 and convert to VCD/DVD has improved a little I think!
Using Dscaler and my TV capture card I can at last get the video on to my PC in colour and a reasonable quality.
However it seems that the only way to do this without drastically affecting quality is to leave standard settings in Dscaler at a Pixel width of 720.
I have tried then using virtualdub to resize but this seems to really affect quality and also for some reason causes some audio lag.
Avoiding the resize stage by burning with Nero Vision Express with a high bitrate is successful but of course with a 720x240 image.
I have successfully used virtualdub to capture and then crop output, but got better quality with the direct Dscaler.
It needs a new mind on this - any ideas?
Grahame
Results 1 to 1 of 1
PAL Capture Black & White
By SGGS in forum Capturing and VCRReplies: 42Last Post: 9th Dec 2011, 05:12 -
Pal-60 Compatible External Capture Device?
By Justin-NZ in forum Capturing and VCRReplies: 6Last Post: 22nd May 2008, 11:30 -
Ghosting on PAL VHS CApture
By tumaz in forum RestorationReplies: 30Last Post: 4th Oct 2007, 16:59 -
PAL60 capture. So what is BTtweak ??
By DB83 in forum Capturing and VCRReplies: 1Last Post: 26th Aug 2007, 13:29 -
Anyone know if the ATI All in Wonder 2006 Edition can capture PAL 60?
By MarksmanR in forum Capturing and VCRReplies: 5Last Post: 29th Jul 2007, 08:10
