ok i set up the vdr file in virtual dub but when i open CCE and i try to add the .vdr file ..i can see the file but when i double click it it doesnt show up in the CCE window ..therefore i cant adjust the settins or encode
Hi
If you read this guide carefully i did mention that you have to use e.g." movie.vdr" this is a file what you have saved, then you open CCE ,when browsing for the directory of your saved file "movie.vdr" you have to IN FILE NAME put 2 " asterisk" like that " **" by pressing shift and 8 on your keyboard.
If this doesn't work just simply choose "all files" this would save your problem.
i think either i or maybe you might not understand what each other are talking about.
from my previous post maybe i should have explained more..
but i created a file from virtual dub ( like it said too in the CCE GUIDE) and named it im.vdr (did i have to use movie.vdr or what)
ok then when i went to CCE then try to add the movie..couldnt see it so i had to change the format to "view all files"
ok i saw the file i created
then i clicked on it so it will load into CCE
but nothing showed in CCE, in the CCE window was no loaded file
did it again and again but nothing...am i missing an update or patch or something for CCE or v-dub
thanx
<font size=-1>[ This Message was edited by: eatin sammiches for lunch on 2001-10-23 16:15:03 ]</font>
searching for a guide....
By videoman3344 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 04:13 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 02:47 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
CCE guide for PAL to NTSC conversion
By alexs_eu in forum Video ConversionReplies: 9Last Post: 21st Jun 2008, 08:41 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 23:34
