ok i want to convert ogm to avi to mpg(so dvd player can read it)... but i want to convert ogm to avi by removing the sub, and the jap translation. Then onto mpg(or vcd).
i have one more thing to ask, if i do all these convert, will my mpg video look different from my ogm???
yes, the quality of the video will reduce.....but for me when you're watching it on TV, you wouldn't really notice it....Originally Posted by moneylee
first make sure you have all the filters and codecs you need to play OGM files........open the file in VirtualDubMod.......goto Streams and then stream list........highlight the first audio (usually the first audio is english) then hit demux to separate the audio......it'll be saved as an OGG files, u can put whatever name you want as the filename.......audio 1 for instance.
then goto the File menu......save it as an "avi".....now u have a separate audio and video, if u want...you can try playing it just to make sure that u got a right audio and video.
after that you have to convert the audio into WAV format cuz it was saved in Ogg format, I used Goldwave to convert it......u can search for it in this site to download it......just open the file in Goldwave and save it as WAV.
now you can convert it to VCD -or- MPG. I used TMPGenc to convert it.....just use the project wizard......select VCD-NTSC....for the video, use the avi file that you have saved in VirtualDubMod.......and then for the Audio, use the file that you converted into WAV format in Goldwave....and that should it!.....let me know what happen.
wmp11 & mpc-hc display audio info on the screen for mpg,avi files
By Danneauxsvh in forum Software PlayingReplies: 4Last Post: 6th Jun 2010, 13:16 -
Help - Need to remove commercials & other bits & pieces from TV show
By jcikal in forum EditingReplies: 1Last Post: 7th May 2010, 16:36 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Creating my own subs for avi & editing subs of ogm & mkv
By retroborg in forum SubtitleReplies: 1Last Post: 1st Jan 2008, 15:33 -
MKV & OGM to RM under 100mb
By bloodyred in forum Video ConversionReplies: 2Last Post: 10th Sep 2007, 18:06
