How do you enter your Serial number for TMPGEnc DVD Author 1.5.20.62
I don't see anything at the top like help.
Most program you click help and then register.
How can I tell how many days left on free trail? and then where would I put in serial number?
If you installed it over an earlier version I don't think you have to enter the serial number again.
If it's a new install then there's a button you click to register when you first open the program. -
I did install over older version but real old version so I need to enter serial number again. Right now just trail version and when I click begin output program disappears.
Yes, I have uninstalled and reinstalled over and over.
Even try to install the old version I have. -
All my problem started when I installed Roxio Easy Media Creator 7!!
Don't know if Roxio killed TMPGEnc or did my trail time run out. I have uninstalled Roxio Easy Media Creator 7 and will never install a Roxio product again. Yes, I know Roxio sucks and never should have installed it in the first place. 5 and 6 killed my computer before so should have learn my leason from before. But I plan on redoing system soon anyways so figure I would give it a try. Big Mistake!! Just wish TMPGEnc had way to check register to see if still good since I was trying to upgrade it. Don't know now if new version did not take my serial number, upgraded too many versions, or if It was Roxio Easy Media Creator 7. I do know Roxio Easy Media Creator 7 messed some other stuff up for my DVD-RW -
If you install from even the earliest version of TDA it will not ask to be registered. I began with the very first version and I am up to the latest still with the same #.
If you were not asked to insert any # during the install or during the first start up, then you do not need it as far as I know.No DVD can withstand the power of DVDShrink along with AnyDVD!
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
