Does anyone know if the Philips DVDR70 is Region 2 compatible only or will it run Regions 1 + 2?
Andy
If you bought your recorder in UK it is likely to be region 2 only.
I bought a multi region from Richer Sounds.
But normally they are just region 2
If you look at DVD Hacks on the left you can put in DVDR70 and it will tell you how to make it region free.
I have seen posts about this and it seems you need a particular All4One remote to be able to hack it.
Hope this helps
Philips DVP3870K Wrong Region
By 2688hk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2012, 02:10 -
Philips DVP3750/F7 Region Hack
By sunnyblueskies in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Dec 2011, 13:11 -
Philips HTS5591 Region Free
By Douwe Egberts in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th May 2011, 08:59 -
Philips DVD region free
By rmb0227 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Sep 2009, 06:38 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 13:29
