Hi all,
I did some encoding with mixed succes, but I've been pulling my hair on this one.
I've downloaded several xvid avi files (res 608x336) from a famous series and try to convert them in mpeg using vdub and frame serve it into tmpgenc.
Everything goes right except that in the output file the resolution seems not to be right... the actors look elongated! although the resolution is set to 352x240.
I've tried several settings in tmpgenc according to what I read in this forum. Nothing helped.
Your comments would be most welcome.
It can be one of 2 things. It's encoded that way (incorrectly) or your source settings are wrong. Your source is 1:1 VGA (it's an AVI after all). It's also in a 16:9 proportion. You going to need to letterbox it some before you re-size it to avoid the skinny heads. Alternately you can cut some off the sides and re-size it as well.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Under Advanced Settings, I would suggest this set-up:Originally Posted by Mercatoros
Source aspect ratio - 16:9 525 line (NTSC) or 16:9 625 line (PAL) depending on your system.
Video arrange method- Center (custom size)
Now change ratio to 640 X 360
Leave all boxes underneath un-checked."Can You Dig It!"
Faster Resolution of Chroma Isssues During MPEG2->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 5Last Post: 27th Apr 2011, 10:56 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
AVI conversion to 16:9 resolution
By kyrcy in forum Video ConversionReplies: 3Last Post: 2nd Jun 2009, 12:23 -
How to reduce resolution and video bitrate in XviD AVI files?
By hibbs in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 12:50 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 17:56
