Hi all,
I have like 50 *.mpa audio files (karaoke) and I want to extract only the left channel (instrumental) of each files.
Anyone know a program that will allow me to do that?
I tried Sound Forge but it wont open MPA files.
Thank You, Thien-An ^________^
Hi,
Open the same file in TEMPgenc and than extract the audio
file to .WAV. After doing this Open the same file in Sound Forge.
It works very well.
Or
Rename .MPA files to .MPG and then Use above steps. Surely works.
Happy
Regards.JUST EDIT & PLAY.................apnait.com
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 20:13 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 10:34
