I seem to be having a problem on the DVDs that I author with several frames cutting off the end of the mpeg-2 files when they are converted to VOB. Is there some reason that movies would cut off early? The individual encoded .m2v files (from TMPG) are the correct length and play out as expected in WMP and PowerDVD. AC3 audio is in sync, everything else seems fine. Authoring in DVD Maestro. Problem occurs in software player as well as set-top player.
Thanks for any help.
Results 1 to 1 of 1
NTSC -> PAL same movie length?
By busta3396 in forum MacReplies: 5Last Post: 6th Mar 2010, 06:30 -
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 00:42 -
TMPGEnc Issues with length of movie?
By doctorgonzo in forum Video ConversionReplies: 1Last Post: 11th Apr 2009, 10:30 -
wrong movie length, audio delay
By KlintIstwood in forum Blu-ray RippingReplies: 6Last Post: 23rd Mar 2009, 14:10 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:20
