just wanted to verify. When I go into tda and tell it to use X video file and replace the audio with X audio file (usually just the cleaned up version of the original audio) it does REMOVE the original audio file correct? I guess I just wanted to make sure it's not still getting shoved onto the dvd and just not being pointed to...
dlv
best way is to play your newly authored dvd and listen for which track you hear...
Always check helpfiles/instructions before leaping... -
I know it's playing the cleaned up track since that is what I specify in TDA..I just wanted to be sure that it is NOT putting the other audio track that is attached to the original mpeg2 file in there. So it's not:
VIDEO <---DVD Plays This
AUDIOOLD
AUDIONEW<----DVD Plays This
But RATHER!:
AUDIONEW <---DVD Plays This
dlv -
Hi muskgrave,
I use TDA with separarte audio and video files as sources and am 99% sure it just uses those.
I'd be surprised if TDA, being the level of quality it is, would do something daft like that. That's whyI didn't go the full 100% - I've never actually confirmed.
Here's a way to check:
I haven't used TDA for a while, but I believe TDA tells you how big the final authored disc is gonna be. If so, use this in place of step 3 below:
1. Go to the DVDRHelp Bitrate Calculator and click on advanced mode.
2. Enter the length of your footage and select 1536 for the audio bitrate (this is what PCM is), or whatever audio bitrate you're using.
3. Author your footage using TDA and your different source files (cleaned-up audio) to a re-writeable (just in case it does do the daft thing).
4. The calculator tells you the total (in the bottom-right corner of the slightly darker green box, just above the copyright statement).
5. If the size of your authored disc = what the calculator says - all's as you want it to be.
Good luck. Post back how you get on...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Ripping 50gb Silly Question
By beric3236 in forum Blu-ray RippingReplies: 8Last Post: 16th Nov 2009, 19:30 -
Silly VideoLAN setup question
By Ensign in forum Software PlayingReplies: 5Last Post: 9th Dec 2008, 00:48 -
Silly mkv format, hd question.
By adkom in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2008, 04:36 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 18:15 -
Silly Question About AnyDVD
By hech54 in forum DVD RippingReplies: 3Last Post: 10th May 2007, 01:29
