New version of FFmpeg.exe is available here (730KB).
It has a fix to the AC3 encoding which better satisfies the AC3 standard. If you were having issues with ffmpeg/ac3 before, it is recommend you get this.
If you want to use it - download it to your SVCD2DVD folder and overwrite the old version.
Thanks to Baldrick for flagging this update/fix.
I hope the fix was for my files..See the link for my first log file. https://www.videohelp.com/forum/viewtopic.php?t=207502
I tried the same files. But it still freezes.. I'm at work now so I cannot upload the log files. But it didn't fix my problem.
Guido -
Thats a different issue. THat file has AC3 inthe audio to start with. The fix is concerned with converting mpeg audio to ac3 audio.
Help: Need to put AC3 into MP4 with ffmpeg
By thuriel in forum MacReplies: 19Last Post: 20th Apr 2012, 05:47 -
ffmpeg encoding to xvid + ac3 5.1 -- can't make it work!
By suroit in forum Video ConversionReplies: 2Last Post: 4th Jan 2012, 17:13 -
Trying to update ffmpeg components
By doodlebuggy in forum ffmpegX general discussionReplies: 2Last Post: 20th Jul 2011, 22:57 -
Another ffmpeg gui (autoffmpeggui) (update 28/07/2009)
By buzzqw in forum LinuxReplies: 12Last Post: 28th Jul 2009, 04:53 -
how to fix: MKV to MP4 with bad ac3?
By cjh1452000 in forum Video ConversionReplies: 2Last Post: 28th May 2008, 04:11
