I know there is a lot of written but it is still not clear to me.
I am capturing from a vhs analog videoracorder the movies i have put there are from a analog camera. These or home movies. I want to put thes tapes to my pc and then edit en author them with pinnacle studio 8 (making the movie's like real movies) en then a menu with ulead dvd moviefactory 3 disc creator.
My question is: which bitrate can i best use and constant or variable?
I know a dvd is looking good at: vbr 4600 - 8000 peak.
But is this nessesary to put the peak so hi? And is it nessesary to use vbr in stead of cbr?
Nessesary for my meaning is when i can see difference on my tv like dissortions of pixels falling etc.
There must be 1.5 hour on a dvd.
Can anywhone give a simple answer or is the materie to complicated.
Your ultimate capture bitrate will depend on what you're going to do with it. Since it looks like you're planning on putting it on DVD and have a time goal of 1-1/2 hours, I'd say start with DVD full-D1, 720 (or 704)x480 if NTSC and 720x576 if PAL, MPEG-2 (DVD), variable bitrate, 48 Khz audio, 224 Khz sampling rate, and start with something in the area of 5500 Kbps average 7000 Kbps peak. Use a compressed audio like AC3 or MPEG-1 Layer 2. Stay away from "LPCM" or "PCM". This should yield a file of about 4 GB, mileage may vary. This will give you a pretty decent DVD. Any shortcomings in the finished product will be a result of the source and not the capture/author process, which is how it should be.
Originally Posted by surferPinnacle Studio 8 and DV home video editing (ver.9 already home)
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 04:35 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
