Results 1 to 12 of 12
    Jul 2003
    london uk
    i have an mpeg file, it is 400mb in size, and it plays for 20 minutes in length. my problem is i want to burn it to either vcd or svcd, but i do not know if the file is mpeg1 or mpeg2. it is very good picture quality, but i would like to know if there is a way of finding out for sure which mpeg type it is. i am using windows xp pro and have right clicked on the file, selected properties and all it says is just file size, nothing there about frame sizes etc. can anybody help, suggest something?
    Dec 2002
    My Swamp
    AviCodec should give you the information you require.
    You can get it from here
    Jul 2003
    london uk
    thanks i downloaded it, heres what it says.
    401 MB (0.0 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 80 %
    Video : 0.0 B, 2500 Kbps, 25.0 fps, 480*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 0.0 B, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    so its mpeg 2, thanks for your help.
    Dec 2002
    My Swamp
    Yes also it's SVCD and not DVD. You can tell that by the audio.
    SVCD has 44100k audio
    DVD has 48000k audio
    BTW your running winXP now don't forget to update your computer details
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Another way to tell it's SVCD is by the resolution(480x576).
  6. Yep! That there be a PAL SVCD, matey. ARGH!
    Dec 2002
    My Swamp
    Yes but they are in UK so PAL is a good thing
    Jul 2003
    london uk
    kool and the gang!
  9. Member teegee420's Avatar
    Dec 2003
    Southern California
    Earth, Wind & Fire! :P
    Jan 2004
    NearBrussels Thats Europe
    Yea, yea. OK wee disco boppers.
    Let me tell ya, if youz want some real music go get summa this...
    http://www.dreamtheater.net/
    ...but youz wont see em on MTV...thez just too good...
    Jul 2003
    london uk
    i was only saying "kool and the gang" cos i have got myself into the habit of saying that instead of just "cool", lol.
    much prefer to listen to www.bassdrive.com
    because that is just kool and the gang! see, stupid i know, but stupid is as stupid does!
  12. Member teegee420's Avatar
    Dec 2003
    Southern California
    I know, dude. I'm just a smart-ass.
