  1. what tools is best( good quality on video and audio) to go from avi or mpg files so i can burn it on DVD.
    most of the movies i have says its mp3 audio and mpeg-1layer.
    How can i get this into dolby 5.1 sound.
    Anyone with a working guide...........i have tried different ways but ending up with only 2ch sound.
    so anyone with mercy are welcome to help.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You can't. Where would the information to create the missing 4 channels come from?
    /Mats
  3. U can make a 'psuedo' 5.1 soundtrack. I think theres a guide here somewhere.
    basics are
    1. Convert audio to wav files
    2. open wav files in surcode softencode
    3. save as ac3 5.1 file
  4. i have tried som guides that use saved wav file and soft encoder...but the result i no good...i can create the six ac3 files but not save them into one 5.1 file.
    Is this a dead end trying this ,or have anyone maked this work.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I think ffmpeg can encode to 6 channel AC3. Again tho, I wonder why, as it'd be like hoping for stereo sound from a mono recording...
    /Mats
  6. You must be doing something wrong. In surcode you load up the wav 3 times, this gives you your 6 channels, and save it as a 3/2 file with LFE (subwoofer enabled) this will save it as a 6 channel ac3 file.
  7. i canīt input my wav file in surcode...(only mono input files may be specified)
  8. ok.. now i fixed it my own mistake.....hade tom many 0 in bitrate ...succeeded to make 5.1 audio and now playing on my surroundsystem.
