ok im kind of new to the editing. I have these 2 programs. I am editing mpg2 dvd compatible. I have about an hour worth of video. I like to edit the video, by adding transitions, Pips and still photo's. My quesiton is this, How can i have the audio go along whith the whole movie. I don't want to loose the audio, i want the audio to go along in the backround and not go out of sync, for example i added a still or transiton for 5 seconds, how can i have the audio still playing while doing the transition or the still or the pip, and when the 5 seconds is over the audio is in sync with the video after the transition is over. I hope this is not confusing?
Don’t take my word for it but I can’t see how you are going to keep the original audio track of the movie playing over still shots, transitions yes as Studio8 automatically fades out and in through the transition. When adding still shots they have no audio except if you add a voice over or music.
In Studio8 I edit my movie first including all transitions, stills, titles etc. then add an audio soundtrack from a CD. You can add soundtrack before but if you add or modify a clip or transition in anyway the programme has to re record the track to allow for this. -
Are you observing loss of video/audio synchronization with both applications?
Jerry Jones
http://www.jonesgroup.net
Originally Posted by tonymehroke -
In premiere, this would be relatively simple.
With videostudio, the best you can hope for is to load the audio as a separate entity in either the voice or music track in addition to loading it with the video, set the video volume to 0%, then try to slice the video track into sections and adding the extra content without shifting the original video. -
Well you have a few options in the studio realm. If you put the pictures in the overlay track along with your transitions it will work fine. Or you can place your video on the video track and lock the audio, so when you mess with the video the transitions will not fade. Now if you have HFX pro you can even expand more with this. Or if you have studio 9, you can place your video in the Music track, lock the audio, then place your video in the video track, mute the audio in the video track and lock it, then split your video where you want to put pictures and then use smart movie to add transitions quickly or add them yourself. So many options, good luck.
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 09:35 -
Ulead Videostudio Transitions - How to Add?
By markannab in forum EditingReplies: 1Last Post: 28th May 2007, 12:54
