Hi. How would I go about putting multiple short DVDs on one DVD+R, having each selectable via menu? Right now I use Sonic MyDVD to record, MPEG2VCR to edit, TMPG DVD Author to author the DVD content, and DVDShrink to put on a disc. Is there a way to read in the DVDs and arrange them like that? Thanks!
should be able to read burned dvd's back to hard drive using TDA and using "add dvd vidoo" option in source setup. Have your previously burned dvd loaded back in your burner drive.
This will let you reconstruct either/both video folders or mpgs back on your hard drive.
Once you've got enough of your small dvd's re-captured, then re-author them via TDA, entering each movie into a separate track... from there, process std. procedure.Always check helpfiles/instructions before leaping...
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 06:50 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 18:07 -
Multiple DVDs in one DVD
By src2206 in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2008, 10:09 -
Home video too big for DVD. How do I put it on 2 DVDs?
By Saaski in forum Newbie / General discussionsReplies: 12Last Post: 14th Jan 2008, 16:00 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 15:12
