    Oct 2002
    new york
    I am having trouble coverting a avi file to fit on a 4.7 dvd using TMPGEnc the smallest i can get it is about 5.5 gig any ideas
  2. for starters, you may want to post a little more info than that. Try posting what your source is and then tell us what you are trying to achieve. Mpeg1 or 2...audio settings blah blah blah. You dont need to go too in depth, just the basics will do.
    Second, you must tweak your settings until you get what you want.
    Boy do I love my avatar!
  3. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    use a lower bitrate
