I'm not sure what the deal is, but I am having trouble using Nero under my Win2k system. For some reason, when I try to burn just a DivX .avi file to CD, I get an error message of "Could not create End Process" or something like that. I tried again with a different make of media, but to no avail. I tried reinstalling it, but it still did the same thing.
Also, I tried to install Nero's ImageDrive. Towards the end of the installation process, it stated that it did not have a digital signature, and that it might not work with my version of Windows, so I canceled the setup. However, it had already installed. So, I tried uninstalling it via Add/Remove programs, but to no avail. It would just bring up the uninstall window for less than a second, and then it would disappear. I tried this a few times, but it didn't work.
I then uninstalled and reinstalled Nero. I tried installing ImageDrive again, but it prompted me with two options:
1. Update to latest ImageDrive version (which it already was; only said this because it detected ImageDrive)
OR
2. Uninstall
I tried uninstalling, but didn't work. I then tried updating to current version. It seemed to do it, but then when I tried to uninstall it, it did the same thing it had done before.
In any case, how do I uninstall it? Does this have anything to do with the problems that I am having with burning? Should I uninstall it manually by deleting it from the Nero folder? Are there system files that I might miss if I do this?
Also, I don't even know what ImageDrive does. What does it do? Do I need it?
Results 1 to 1 of 1
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 21:21 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
