Hi,
I have a DVD which contains Music Videos. I have ripped a single music video from the DVD (using DVD Shrink). The single music video has itself become a compatible VIDEO_TS file folder of size 313MB.
What I wanted to do was find out first of all whether it is possible to burn this VIDEO_TS folder onto a standard CDR (along with the AUDIO_TS folder ofcourse) to create a DVD player compatible disc?
Also, if this is possible then is it possible to create an Audio CD with CDDA tracks and then the Music Video in DVD format.
ie. the CD is basically an Enhanced CD but the only difference is that instead of in a computer, the cd will play the music video in a standalone dvd player. (and ofcourse the audio tracks will play in a standard hi-fi and ignore the DVD section).
Please tell if this will work... if not then is there any other alternative which will allow the cd to play in a standalone dvd player as well as the audio tracks in a hi-fi system?
Thanks.
The Enhanced CD trick works because a CDPlayer always reads the first track and stops. The Computer reads the last track by default and thats where the video is.
I have a feeling that what you want to do wont work for the simple reason that both CDPlayer and DVDPlayer read the first session.
MiniDVD is not a standard and not many Standalones will recognize the DVDStructure but instead offer the VOBs as seperate files.
cheers
maa
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
.cdr on a DVD+ needs to be converted
By jamesmarcustucker in forum Video ConversionReplies: 20Last Post: 8th Sep 2007, 16:40 -
.cdr file on a DVD+
By jamesmarcustucker in forum Video ConversionReplies: 1Last Post: 6th Sep 2007, 08:13 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 13:04 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 12:26
