http://www.dvddecrypter.com/default.asp
Change Log
DVD Decrypter 3.2.0.0 (29/02/2004)
Added: Lock volume during ISO Write or Erase
Added: Disable Media Change Notification for currently selected drive
Added: 'Untested' support for Double Layer +R media burning
Added: Stream information in filenames for File mode Demuxing
Added: CSS code now checks all VOBs in VTS set if the key for a single file cannot be found
Added: CSS code now detects the presence of CSS in supposedly unencrypted VOBs
Added: Quick drive letter change on destination path - in context menu
Added: Command Line switch '/SHUTDOWN' for ISO Write mode
Added: Region mismatch dialog box now displays the drive region and the disc region to make the problem easier to see
Added: A lot more 'status' message to show the user what the program is doing at all times
Added: A workaround for NEC drives that don't have their regional code set - they don't follow the specs
Added: Code to put the system tray icon back in the system tray if 'explorer.exe' crashes
Added: '% complete' for more of the 'lengthy' operations (Synchronising Cache, Finalising Disc etc)
Added: 'Question' event sound to the 'File Replace' dialog box
Added: ISO Read mode now uses the Filesystem specified capacity for the disc capacity when reading from DVD+RW media
Added: ISO Read mode now silently (almost) terminates when it reaches the end of the disc before it originally thought it would
Added: Setting 1x for 'Set Read Speed' will put Pioneer DVDROM drives into 'Quiet' mode. 'Max' will put them into 'Performance' mode
Added: 'Vendor Specific' inquiry information is now shown in the device 'capabilities' page accessed via the device context menu
Added: Support for XBOX images that have had their ISO filesystems removed
Changed: CSS code has been rewritten to cope with strange happenings and should error out a lot less now
Changed: Stream Processing in File mode - Shows information for more streams (i.e. DTS)
Changed: CSS code I/O Debug mode logging to make it more useful in identifying problem
Changed: I/O Debug mode logging to make it more useful in identifying problem
Changed: VOB CSS 'Encrypted' flag is no longer removed if the program hasn't actually decrypted the file
Changed: NSIS installer has been updated to be more 'user friendly' for reinstalls etc
Changed: SPTI Device detection code has been cleaned up - code for NT4 no longer effects 2000 (and newer) OS's
Changed: ISO Write mode code to hopefully make it more stable
Changed: Sectors are no longer skipped in basic IFO/File modes due to 'Pack Header Not Found' errors
Changed: Logic behind getting the free disc space. It no longer uses the root folder but instead the one you've actually selected
Changed: Source device drop down list now shows 8 devices before scrolling
Fixed: A problem in the Image File 'Format' detection code where it could error out trying to load small images
Fixed: Set Read Speed - previous version always set it to 'Max' regardless of the actual setting
Fixed: ISO Write mode displayed 'Decrypt' as the button tooltip instead of 'Write'
Fixed: File mode stream processing via CLI no longer includes unwanted streams in the VOB
Fixed: 'Set Hardware Read Error Reties' should no longer cause certain machines/drives to hang
Fixed: A problem comparing drive/disc regions that could lead to a 'mismatch' when one didn't really exist
Fixed: Misalignment of a few controls within the Settings
Fixed: Tab order of a few controls within the Settings
Fixed: Issues with PCM demux in IFO/File modes
Fixed: Issues with PCM information in File mode stream processing dialog
Fixed: A small problem with the IFO parsing code that could lead to the wrong video resolution being displayed
Fixed: A bug where the Device Buffer thread could cause a 'Divide By Zero' error
Fixed: NEC (and alike) drives no longer display 2.3x and 3.9x for supported write speeds in ISO Write mode
Fixed: 'Pack Header Not Found' entries in the log caused by a previous 'Read Error'
Fixed: A nasty bug in ISO Write mode when converting 2352 sectors to 2336 ones
Fixed: A nasty bug in ISO Write mode when converting 2336 sectors to 2352 ones
Fixed: A logic error when setting the write speed for 'Erasing' a disc
Fixed: Copy + Paste issue in ISO label change dialog
Fixed: A problem ('Failed to set Write Parameters') when burning on 'older' CD drives
Fixed: A problem with file splitting code in File mode
right now the only mirror with theupdated version seems to be doom9
Had anyone updated their Liteon 5045 or other standalone to SATA DVD ?
By bithead9 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 29th Nov 2011, 18:31 -
Advanced High Definition Video Disk Creator v2.9B(AVCHD DVD) UPDATED
By Gherudos in forum Video ConversionReplies: 31Last Post: 3rd May 2011, 09:10 -
Updated Drivers Software
By mn072065 in forum ComputerReplies: 7Last Post: 9th Mar 2009, 05:23 -
Authoring a DVD with updated audio files
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2007, 06:25 -
Updated TMPGEnc
By avz10 in forum ComputerReplies: 4Last Post: 24th Jun 2007, 13:20
