Hi,
I have a region 3 NTSC DVD-9 original of Battle Royale II.
I have been baking up DVD's for a little while now and have not come across many problems.
However, when i copy this DVD, the picture is fine, the sound is fine but the subtitles play silly buggers. There are three choices of subtitle on the original disc, but only one of them works when copied.
I normally use DVD Shrink, DVD Decrypter and Nero.
I have tried ripping with both Shrink and Decrypter, but i cant get the thing to work.
Has anyone any suggestions on how to get it to work?
Might it be easiest to rip the subs seperately, and then reattach? If so how do i rip just the subtitles? (i have looked in the guides but can not find anything)
Thanks in advance
Zworg2
Results 1 to 9 of 9
thank you i just trying that..Originally Posted by steveryan
i hope it works..
Zworg2 -
hi,
ok i have ripping the subs, but they come up as IFO and VOB.
How do i get them into SUB or another recognised subtitle format that i can then add to a video?
or ahve i used a wrong option?
this is my screen prior to ripping....
have i missed something.......
should i be using DSC, Demux or Raw?
thanks in advance
Zworg2 -
Maybe my memory was playing tricks on me but I was sure you could use DVD Decrypter to rip subs. I've just had a mess about with it and I couldn't get it it to work either
Have you tried Sub Rip?
Yes i got there on my own, but you can either rip the vobs to HD or process direct from DVD.Originally Posted by steveryan
I done this bit now...
Thank You.
Zworg2 -
Maybe I'm being a little dense here, but I use DVD Decrypter, DVD shrink and Nero 12 Platinum in that order to get the DVD onto a Blu-Ray disc (I like the larger storage capacity). I have a few unencrypted foreign films that I want to get onto the disc with the subtitles showing. One worked just fine, but I think that is because the movie had them turned on or incorporated to begin with. I have others that you must go into the menu and turn the subtitles on.
As stated above, I want the subtitles already showing when I play the disc. Any ideas?
I do have a work around, but I am afraid that the quality will be diminished.
Thanks. -
... and since the corpse is in the open.
You can use DVD Remake or PGCEdit to have a pre-sommand to turn on the subtitles.
DVD Copying Problem
By Live2WinForever in forum DVD RippingReplies: 4Last Post: 24th Feb 2010, 03:02 -
Problem copying pictures off DVD...
By impmon2 in forum DVD & Blu-ray WritersReplies: 7Last Post: 21st Apr 2009, 23:45 -
Copying Divx with its subtitle
By dreamcatcher76 in forum SubtitleReplies: 12Last Post: 17th Oct 2008, 06:11 -
Problem burning/copying on dvd-r
By reminho in forum Authoring (DVD)Replies: 26Last Post: 12th Sep 2008, 00:28 -
Problem Copying Homemade DVD
By Anonymous642 in forum Newbie / General discussionsReplies: 8Last Post: 28th May 2007, 13:04
