Hi could n e one please help me, i collect all the Disney films for my 5 year old daughter, i just purchased Finding Nemo on dvd, i back up all my Disney films to keep them put away from her and she has the back up i have made, i have tried backing up Nemo but there seems to b a sound problem when played in the pc, i also had a problem with my Seabiscuit dvd last week also with the sound, does n e body know if there n e type of protection that has lately been introduced into the original dvd films ???
Many Thanx
Max
PS, if so is there n e way around the protection
Results 1 to 10 of 10
haven't done nemo but i did do Seabiscuit (movie only) and it came out just fine. i used dvd decrypter dvd shrink and nero....
How Big A Boy Are Ya? -
When u done seabiscuit did u have to alter n e settings in DVD Decryptor ?? or did u just let it select main movie files on it's own ??? The problem i had was that when i ripped it to h/drive, through dvd decryptor, i had no sound in the 1st vob, all the other vobs were ok. Or would it b the version of Decryptor i am using - 3.1.6.0 ?????
Many Thanx
Max -
Wat version of DVD Shrink did u use ?? i tried it with version 3.1 and set at full disc, automatic, could u please help me by letting me know wat settings u used, or changed in n e
Many Thanx
Max -
used 3.1.6. didnt do the whole movie just the main part. i know audio remapping is unchecked. the rest on that screen is checked. and the hide audio and subpicture is unchecked. file i/o tab everything is unchecked. i do usually take out foreign languages though, but leave english 5.1. i think on nemo there was alot of english sound options that said 0mb, i left those checked.
I used 3.1.5, just found out, when u say Audio Remapping is unchecked, where do i find this setting please ???, just checked all the other settings and they r correct
many Thanx
max -
under preferences. output files. sorry, its called logical remapping last box. you might wanna try upgrading www.dvdshrink.org
How do i use dvd shrink to rip movie only ?? have used it in the past to do full disc, that is the way i set it up for Nemo, did want to have the xtras etc on same disc
Thanx
max -
Just go to Re-author mode, then drag the main movie over from the right window to the left. Then click on the compression tab above and uncheck any audio and subs you don't want.
How to copy a protected DVD?
By weirdwing in forum DVD RippingReplies: 28Last Post: 10th Dec 2013, 06:21 -
copy protected dvd?
By just in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2008, 17:04 -
copy protected DVD
By marcelcukier in forum DVD RippingReplies: 12Last Post: 7th Oct 2008, 09:36 -
Help Copying a protected DVD
By leahratcliffe in forum DVD RippingReplies: 3Last Post: 7th Sep 2008, 09:44
