I am thoraughly confused by the resolution setting instructions in TMPGEnc Plus! After downloading a movie file that has a resolution value of 640X360 and using TMPGEnc Plus to encode it can the resolution output be changed to a number used by NTSC compliant televisions (720X480 352X240 etc) during the encoding process?
If you have allready encoded a file to 640X360 can it be changed to a resolution that can be authored in TMOGEnc Author to create a DVD?
If you already have an mpeg with a 640x360 resolution there's not anything you can do to make it a DVD compliant resolution. If you have source files with odd resolutions, change the video arrange method to "Full Screen(keep aspect ratio)", just make sure you are using a legal DVD resolution. You can do this by opening up the settings dialog and clicking on the advanced tab.
Try resizing it to 720x400 and add a 40 line border at the top and bottom to make it a 720x480 frame.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Actually, TMPGEnc will automatically resize it to 720x480 since your file perfectly fits into a 4:3 ratio. It's cool for a DVD. Just set Source Aspect to 4:3 in Advanced tab and shiznits and arrange method to full screen (keep aspect ratio). W00T.
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
which settings in compressor for MOV-Container, PAL(SD)-resolution, DV-Code
By perik in forum Authoring (DVD)Replies: 0Last Post: 30th Mar 2011, 03:15 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
