Results 1 to 26 of 26
  1. does anyone know any software i can use to convert asf
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Dr. Divx can convert to Divx and both TMPGEnc and Canopus Procoder can convert to mpeg.
  3. i tried with tmpgenc but it said something like unsuported
  4. Member lacywest's Avatar
    Aug 2001
    California
    Use Intervideo WinDVD Creator 2 ... use file output option ....
    and choose HQ setting ... 3 choices of audio ... AC-3 ... LPCM or Mpeg audio. Result will be a large nicely done DVD Compliant Mpg 2 Video.
    I convert WMV videos with it all the time.
  5. i don't have a dvd burner.
    and i wanna make an svcd
  6. Originally Posted by jemel46
    ok....TMPGEnc will work fine for converting both asf and wmv, at least it does for me
    first, you need to have DirectX8.1 or later installed.
    Then you need Windows Media Player 9 installed, or if you don't want to upgrade to that player (I still use 6.4 and WMP Classic), you need to install the Windows Media Series 9 Runtime files.
    a quick search of google will yield plenty of download locations, or just go to Microsoft and search there
  7. how do i install DirectX8.1
  8. Member lacywest's Avatar
    Aug 2001
    California
    You can go here to the link below and see converting to SVCD can be done too ....
    https://www.videohelp.com/forum/viewtopic.php?t=198974&start=0&postdays=0&postorder=asc&...light=lacywest
  9. i know how to convert wmv i just need to know how to convert asf to an mpeg
    Jul 2003
    michigan
    convert to an avi with this program, http://www.geocities.com/myasftools/ and then convert to mpeg
  11. Member teegee420's Avatar
    Dec 2003
    Southern California
    WMV and ASF are pretty much the same thing. Did you install Dirext X yet? Try opening the ASF in TMPGEnc again. If it doesn't work right away, try raising the Directshow Multimedia File Reader priority by going to Options>Environmental Settings>VFAPI Plugin.
  12. im downloading it now
  13. i finidhed downloading Dirext X and it still says error or unsupported file please help????????
  14. Member teegee420's Avatar
    Dec 2003
    Southern California
    Did you do this already?
  15. how do i do that
  16. Member teegee420's Avatar
    Dec 2003
    Southern California
    Follow the menu steps that I repeated in my last post and then right click "Directshow Multimedia File Reader" and select "Higher Priority". Change the value to 1 or 2. After that try opening the ASF again.
  17. where do i go to change these settings is it in tmpgenc or something else
  18. Member teegee420's Avatar
    Dec 2003
    Southern California
    The menu steps I described are for TMPGEnc.
  19. Originally Posted by teegee420
    dude you must be the most patient man on this board can't you pop round and show him
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  20. it still doesn't open wat now??
  21. Member teegee420's Avatar
    Dec 2003
    Southern California
    Try installing Windows Media Series 9 Runtime Files, then give TMPGEnc another go. If that doesn't work, best of luck to you because I'm fresh out of ideas.
  22. it still didn't work
  23. is anyone gonna help
  24. Take a course would help !!!
  25. WAT COURSE
