Hi.
When I use the wizard in TMPGEnc I get to a screen where I can chose the size of the output-file...I think itīs in screen/step 4/5.
Itīs very handy to set it up in 99% to be sure itīs bitratrate gets maximum quality for the 80-min disc.
I have then read somewhere on this excellent site that itīs much better to skip the wizard and set it up manually...why I donīt know, but it suits me fine if the process get faster this way.
My question is:
How can I get this scren/option if I set the file up manually?
Today I tried to get a 3 hours film in thre parts..it fits almost exactly if I split them in 3 pieces and use 99% of the disc-capacity.
If I donīt use the wiz-mode I couldnīt possible know what size the outputfile get when itīs finished.
Any answer is highly appreciated.
Stefan (Sweden)
Agree with johns0 reply.
to answer your screen question - AFAIK. you can't.Always check helpfiles/instructions before leaping... -
Actually if you give it a little extra bitrate and lower the quality level a little it will still maintain quality but use less bits since it will be utilizing bits more efficiently, more VBR. Actually yields higher quality
If you don't use the wizard then you have to use a bitrate calculator, look in the Tools section for one.
"Art is making something out of nothing and selling it." - Frank Zappa -
You can use the wizard and still adjust all the other settings manually, just don't change the bitrate after setting it in the wizard. Best thing to do is make your own template to use with the wizard.
Also, most of the time even 101-102% will fit on an 80min CD without having any overburn. I usually just enter 800 for the estimated file size then round up the bitrate and I've never had a file turn out with even a full minute of overburn. -
Hi all!
Thanx for the quick answers.
I now know the settings more, to get it the way I want.
Thanks again
Stefan
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 07:05 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
TmpGenc Authoring Works 4 - how to set bitrate?
By mrhata in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 00:40
