Hi, I have a problem for authoring a DVD.
I've tried with several dvd authoring software like TMPGEnc DVD Author and DVD-Lab and I always get the same error, after compliling the dvd, the audio and the video are OUT OF SYNC!![]()
The video I'm using is captured from an analog capture card called Pinnacle MovieBox USB and through the Pinnacle Studio v8 and saved directly to MPEG 2 (720x480x32, 29.97 fps, 48,000 Hz Stereo, Video Pixel Aspect NTSC DV,Video Interlace Upper field first) in two parts of about 2gb each one, and then I open it on the DVD-Lab.... and at the finish I open any of the vob files and....![]()
I don't know what else to do, please anybody help me!!!!
If the a/v sync is simply offset, you can re-sync in virtualdub, TMPGEnc Plus or some other editing apps by adjusting the offset.
If the sync is good for say half the movie and then goes out, use Virtualdub to find bad video frames.
If the sync slowly but consistently drifts out over the movie, might as well get a device with a/v locking like the canopus advc100 and save sweeping up all your pulled-out hair.
Look for the sticky post at the top of the capturing forum for more on a/v sync probs...Always check helpfiles/instructions before leaping...
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
