  1. I have downloaded a movie that came in 2cd's.
    When i tried to put them together in virtualdub it seems
    that they have different sampling rates.
    Is there a way to fix this so i can make 1 movie out of 2cd,s?
    THNX
  2. Member Sugar's Avatar
    May 2002
    NY, USA
    You can change sampling rates with SSRC. If the command code seems too complicated, you can do it through the BesweetGUI.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Save both parts in vitualdub with video on direct streaming and audio on full processing mode,then join the 2 saved parts in virtualdub.
