ok heres the deal... i have an avi movie encoded with xvid(its a dvd rip)...i usually convert my files to mpeg with tmpgenc but for this file (which is about 750 megs) the conversion would make it over 4 gigs in size...not wanting such a big file, i decided to put it as is on a cd using nero. it then encoded it for about 2 hours and burned it no problem. so i put it in my dvd player and the picture looked nothing like my original file (which was 528x288). the image was fullscreen and all stretched...is there any way i can keep the image widescreen on my tv? please help
I couldn't agree more. Nero allows ZERO control of its encoding settings and as you discovered, it often yields poor results. Definitely go with TMPGEnc and as GodOfKnowledge stated, use Nero only to author. You should also select a 4:3 aspect ratio and change the video arrange method to "Full Screen(keep aspect ratio)".
...Or you can use 16:9 aspect ratio and and use "Center - Custom Size" to get the picture size correct.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
problems importing widescreen video
By video_enthusiast07 in forum EditingReplies: 1Last Post: 10th May 2010, 02:18 -
Problems Exporting Widescreen 16:9
By Funky Monk in forum EditingReplies: 3Last Post: 12th Sep 2009, 11:13 -
Convert avi to 16:9 widescreen
By sknoxxx in forum MacReplies: 4Last Post: 28th Aug 2009, 20:50 -
AVI widescreen fix?
By robburne in forum Video ConversionReplies: 5Last Post: 23rd May 2008, 13:29
