I've been having problems with certain codecs i try to capture with, with my ATI All In Wonder 9600 Pro. I try selecting the YVU9 codec but then when i go back into the screen UYVY video format (Native) is selected. Same with every other codec that starts with Y that is directly under it (YUY2 and YV12). It could possibly have something to do with a serious problem that had happened before. I did something stupid and was trying to put more slack in the chord (the purple box chord) so that the new video and audio chords i got could hook up to the purple box. While i was doing this the TV and my Computer was on and it must have sent an electricity into my card. My card is fine now, it seems, and can capture with huffyuv fine. I'm thinking it could possibly have something to do with that, maybe it corrupted the codecs. I'd use Huffyuv but for some reason it just looks noisier than the YVU9 codec. The YVU9 codec looks softer to me. I have the latest mmc so that can't be it either. I'd try to uninstall the codecs and reinstall them but i don't know how. Please help.
Originally Posted by Twistid
There are two ways of de-installing the codecs (or anything)
1) The easy way
through settings --->control panel ----> add remove programs
2) the hard way
find and delete the actual files on you hard drive.
Zworg2 -
I sort of know what to do now, but im not sure what codecs i should remove. So, i'll make a list on here of what codecs are on here, I'm not sure if which one could be conflicting with the yvu9 codec and i dont want to do anything drastic that could mess my computer up.
UYVY
YUY2
YVU9
YV12
WMVideo Encoder DMO
MSScreen encoder DMO
WMVideo9 Encoder DMO
WMVideo8 Encoder DMO
MSScreen 9 encoder DMO
DV Video Encoder
Indeo video 5.10 Compression Filter
MJPEG Compressor
Cinepak Codec by Radius
Huffyuv v2.1.1 - CCESP Patch v0.2.2
Intel 4:2:0 Video V2.50
Intel Indeo(R) Video R3.2
Intel Indeo Video 4.5
Indeo Video 5.10
Intel IYUV codec
Microsoft H.261 Video Codec
Microsoft H.263 Video Codec
Microsoft RLE
Microsoft Video 1 -
Sorry....i dont know which may be conflicting...but i dont think the conflicts are necessarily that predictable.
If you do not need any of the codecs you listed i would remove them.
otherwise you may need to experiment or wait for a more knowledgeable visitor to these forums..
Zworg2 -
I'm still having problems. Right now i'm practically just shooting in the dark, can anyone else help??
I'd say it's MMC 8.8 or 8.9 causing the problems.
If you hosed your system, speaking in terms of codec troubles, the only way to TRULY fix this is to reformat and reload Windows ... as well as be careful with codecs in the future.
Been there, done that, never gonna forget, never goona do it again.
Some of the damage done is nearly impossible to track down.
On the other hand, don't see why unplugging breakout box would do anything. I've done this myself a few times, no troubles. I don't think that's the cause, not at all.
Try to take off the new MMC and put on 8.7 instead. If that doesn't work, go ahead and plan on a reformat. Then you may want to just uninstall everything codec-wise. If it works, great. If not, nothing lost anyway since you'd reformat.
Bad situation. Good luck.Want my help? Ask here! (not via PM!)
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Where have all my codecs gone??
By Mitchum22 in forum Newbie / General discussionsReplies: 10Last Post: 9th May 2008, 11:40 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
