Hi,
I need help on converting what's on a DVD to .mpeg file (extention).
I have a 16 movie clips of mpeg files and I put these in TMPEGEnc DVD Author to author a movie DVD. After successfully authoring a DVD, I deleted those movie clips in mpg. Now I want to get those movie clips back in their original form (mpg). How do I do this from an already made DVD?
What should I do? Or what programs do this kind of converting?
Do I have to rip the DVD to video_ts and audio_ts files using DVD Decripter, if so how do I convert from there with with video.bup and video_ts.ifo files back to mpeg files.
Is there a better way to do this or direct way from a DVD to mpeg files?
thanks.
Two things to take into consideration with this method:
1) You will need the TMPGEnc MPEG2 Plugin to import the VOBs.
2) If you authored your DVD with AC3 audio, you will also need to deal with it (through plug-in or external decoder). -
Originally Posted by GbMedusa
Ok, I currently have TMPGEnc DVD Author (retail version). Do I need to download this MPEG2 plug-in? How do I know that I already have or not have this plug-in installed?
What does this plug-in do? Does it help me extract the VOBs into mpeg files? Probably a dumb question but I've never used this feature (MPEG2 plug-in) of TDA, so not sure what to do with it.
And yes it happens that this is an AC3 audio. How do I convert AC3 audio from VOBs files to video+AC3 audio in mpeg file? In other words, if the DVD has AC3 audio, how do I convert the VOBs to become mpeg file with AC3 sound? Any good program for this kind of conversion?
Thanks GbMedusa. -
Originally Posted by proxyx99
I've checked out these 2 programs and they seem like doing the same job. So which one is better than the other? And when I extract audio and video separately like that, how do I combine video and audio together?
Is there a chance of video and audio not in sync when you combine them?
What program is good for combining video and audio without having a sync problem?
I have AC3 audio, so I'm not sure what programs would join video with AC3 without causing problem.
Thanks for the advice. -
You can use TMPGEnc to demux (separate) or mux files (combine). This is a standard process and after combining they should be in sync. You need to experiment with both (they will also mux files for you). Every program has it's own angle so both are useful. You need to do some experimenting to know their functionality.
Why Can't I convert the whole file in mpeg streamclip?
By alphonsecpone in forum Video ConversionReplies: 0Last Post: 5th Mar 2011, 09:24 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
How do I convert a HD MPEG-2 file to MP4?
By Newtype in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 00:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30
