I got this error when I try to convert "AVI to MP2" using BeSweet 1.4 via GUI v0.6.
Error 58: Error : Unknown Input-File Format
The AVI is a Xvid/Divx with VBR MP3. I have VOBinput.dll and have tried tooLame and MP2Enc.
Also, I have a question on stereo output mode.
I'm pondering whether to choose stereo or Dual channel. Dual channel sounds higher quality to me. I checked the file with AVI codec and it says 2 channel and with GSPOT, it says
122 kb/s (61/ch, stereo) VBR LAME3.92
Does this mean it qualifies for Dual Channel?
This is a bug with 1.4... Use the latest beta release and it will be fine.
|SYSTEM SPECS|
- Abit NF7-S Rev 2.0
- AMD Athlon XP 2500+@3200+
- Corsair Value 1GB DDR400
- 120gb SATA + 200gb IDE / 7200RPM
- eVGA Geforce 6800 @ 420/885
- LG GSA 4082b DVD Burner
- Prolink PlayTV Pro Ultra
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 04:17 -
Premiere Pro 'Error Compiling Movie - Unknown error'
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2012, 17:43 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 20:55 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 10:10 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59
