I'm trying to use Alphonics guide on DVDx ripping to VCD. I use all the settings he specifies. The resulting mpg has audio that cuts out every few seconds. I even ripped the dvd files first and worked with those after searching for this issue on the forum.
I was able to rip a different dvd fine...though I did have to change a setting: for deinterlace filter I had to set it to Interpolate. I don't even know what that means, but as the last option it worked in getting rid of the squiggly lines when stuff moved.
Anyone know what I can do about the audio issue though?
I'm using DVDx 2.3 to convert DVD(I rip the vob files using SmartRipper) to VCD and I also encountered this problem. Is there any quick fix to this?
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 18:43 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 12:03 -
DVDx dropping audio at end of vob
By shira in forum DVD RippingReplies: 0Last Post: 21st Jan 2008, 23:42 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 01:53
