Long time reader, first time poster...
I have a particular live concert dvd (The Corrs rule!) that I have converted to a single audio .wav file using dvd decrypter. My intention was to burn it to audio cd so that I can play it in my car cd deck. Of course, I'd like to insert chapters (whether at each song, or 5 minute segments), but Nero6 makes me insert 2 second gaps between tracks, and Nero can't insert gaps anyways because there's no break in the audio. Is there another application that I can use to achieve my objective to insert chapters without a break?
TIA
CDwave .....it also RULES....
http://www.homepages.hetnet.nl/~mjmlooijmans/cdwave/ -
What I do is this -
In Nero hightlight all the tracks from 2 onwards, then right click and select properties, change the pause to zero and hit apply. Leave track 1 how it is and burn your cd.
Edit, this is of course after you've made your chapters. -
I do this using nero
add your concert file , right click on it and go properties then indexes, limits, splits then add your chapters by pressing split at the appropriate places.
after that when you go back to the first screen you willl see multiple audio files
then do what steveryan said to remove the 2 sec gap between songs
DVD Architect Pro v5.0b Help - Gaps Between Chapters
By shawncumby in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2010, 01:23 -
Tool to locate movie file audio gaps?
By fvisagie in forum AudioReplies: 1Last Post: 28th Aug 2009, 10:58 -
Philips DVD dvp 3040 gaps between audio tracks
By dancer in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Dec 2008, 17:31 -
Audio gaps/glitches/hiccups when importing long play DV footage
By teraldlarwood in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 12th Apr 2008, 08:34 -
Audio gaps in wmv files in Sony Vegas
By CompMike in forum EditingReplies: 4Last Post: 14th May 2007, 13:07
