dis mite b a dum question but is it possible to connect a vcr to pc so dat films on vcr can b converted to vcd? also is dis possble wit a dvd standalone player ?
thanx 4 ur help
Yes, this method you are looking for is called capturing. You will need a capture card, where you can hook up your DVD, VCR, Camcorder etc.
If you are interested there is a section in the "HOW TO" section all about capturing. When you are interested in the different sorts of capture cards go to the "Other" section and choose "capture cards".
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52 -
my PC stats plz help can i edit on this
By Kigi in forum ComputerReplies: 8Last Post: 30th May 2007, 03:30
