just a question
how 2 join avi files with different audio streams have different sampling rates
with virtual dub
Results 1 to 11 of 11
You can't really. Beleive me, you're better off converting both avi's to mpeg, joining those, then converting back to avi if you must.
So as MPEGs the could be tied together 'cause I have a movie that is just likle that.
Thanks?
(sorry for the hi-jack) -
As long as the mpegs have the same encoding properties they should join just fine. Just make sure you use the exact settings for both mpegs you create. If the avi's aren't the greatest quality, convert them to VCD mpegs.
That's usually a good idea but not always necessary. Better safe than sorry though, right?
yeah thats true...
all 441000?
do u know if i can make a svcd with menus with the mpeg files im converting? or do they all have 2 b joined 2 1 file'? -
If you're making an SVCD, then 44100hz is the only way to go. You can create SVCD menus, yes. Not much point if you join the two files though. You can create some decent menus with Nero. You can also use VCDEasy if you have the commercial version. The shareware version only lets you create a maximum of 400mb per disc.
Absolutely. Give Nero a shot. One thing you should know is that not all DVD players allow you to use SVCD menus. You won't know if yours does unless you try though.
damn... i think mine does cos i stuffed up 1 vcd b4 n it came up with just a picture of teh movie i was authering...
but i will try
thanks man
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 9th May 2010, 00:16 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 22:14 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 15:32 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 10:30 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 11:06
