My TMPGenc won't encode this episode I downloaded. I watched the episode and the picture freezes in the middle and the sound keeps going. I you fast foward a bit though it continues. Is there any way I can fix it because the encoder keeps stopping at the part where the video freezes and it is making me mad!
use this on the avi first
http://www.vcdhelp.com/faq.htm#fixdivx
and download the divxfix.zip program
that sounds like a common divx 3.11 problem..
I have successfully converted movies with bad frames by frameserving them from V-Dub to TMPGenc. Try that.
If the bad frames aren't to bad, you aren't getting any out of sync audio.
Trying to fix a .mov that was corrupted after using undelete software
By Elderain in forum Newbie / General discussionsReplies: 10Last Post: 11th Oct 2012, 12:47 -
mp4 file corrupted. Very important file. Need some help!
By seanloughry in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2011, 17:54 -
m2ts file corrupted, how to fix the chain?
By Srivas in forum EditingReplies: 7Last Post: 13th Mar 2011, 10:42 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 00:51 -
how to fix a corrupted file?
By sharmine in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 17:03
