Hi,
I've just tried to author some SVCD's to one DVD using TNPGEnc DVD Author. I patched every SVCD with DVDPatcher, inserted them into TMPGEnc and repatched them so that TMPGEnc didn't refuse the files.
But after authoring the DVD I recognised a lack of about 10 minutes at the end of every SVCD and the audio is out of sync from the merging point on. Except from that the DVD works fine.
So what's wrong?
Additional question: It took about 45 minutes to author the DVD with my Athlon 3200 and 512 MB Ram. Is that usual? I've read about 15-30 minutes.
Its not unusual since your audio was must likely re-encoded from 44khz to 48khz to make it dvd compliant ,i encode my svcd the slow way so i dont get errors.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
