Hello all,
I have an occasional problem after ripping one of my films using DVD Decrypter and trying to open it in DVD Shrink I get an error during the initial anlysis. Something about missing a non existent .VOB file...
I've found some info regarding this that points to a possible problem with my Pioneer 120S DVD player. Someone seems to have been able to correct the issue by using IFO Edit - something about stripping streams.
I do have a copy of IFO Edit installed, but I have no idea how to use any of the features.
Could someone please help me understand what this "strip streams" feature is all about? Maybe this will solve the problem I've been having.
Thanks!
Jay
Have you tried ripping it with DVD Shrink, instead of DVD Decrypter ?
Also what version of DVD Shrink are you using ?
and is this an original DVD or a copy ? -
I'm using DVD Shrink 3.1 - but the problem seems to happen with 3.0 beta 5 and 2.3 as well... I've ripped with DVD Shrink in the past and about 75% of the movies won't play in my DVD player, so I've been using Decrypter only.
- J -
Try the latest version.
DVD SHRINK VERSION HISTORY
Version 3.1.6 - 23 Feb 2004
Fixed bug which caused occasional skipping/freezing of output
DVD during playback on some players.
Fixed bug which caused non-display of menu buttons in some
output DVDs.
*Fixed ripping from Pioneer 120S drives.*
Added support to change drive region of RPC2 drives in case of
region mismatch with disc.
Set the read-speed of DVD drive to maximum before analysis and
encoding (few drives support this function). -
Sounds lovely - I'll give it a try and maybe I can use it for ripping from now on...
But what about these files I have on my drive now that won't open? Any advice for modifying them in IFOEdit so they can be opened in Shrink? They won't open in the new version (3.1.6) either.
Thanks! -
Sounds like you ripped the main movie only, rip in file mode and select all files. Good luck.
DVD Shrink structure problem
By janefield in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2010, 09:11 -
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 08:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 21:28 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 09:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 11:21
