I've been using TMPGENC to convert DVDs to (S)VCD. Works fine, and I know that there will be some quality loss when encoding to a lower bit rate and to the smaller frame size . My question is, is there any way to reduce some of the "halo" noise around objects (especially people in the video) so it isn't as pronounced when converted to S(VCD) ?
Thanks in advance, and my apologies if this has been asked before.
Results 1 to 1 of 1
Determining audio cassette noise reduction encoding type?
By jbd5010 in forum AudioReplies: 5Last Post: 28th Feb 2012, 21:18 -
cleaning excessive noise with VirtualDub and Neat Video
By defiantclass1 in forum RestorationReplies: 11Last Post: 16th Aug 2011, 09:24 -
Artifacts/noise around text in Xvid encoding, and not with x264?
By nyriador in forum DVD RippingReplies: 4Last Post: 21st Jun 2010, 11:58 -
Cleaning Up/Remove video noise
By Soixante in forum Video ConversionReplies: 5Last Post: 5th Apr 2010, 18:34 -
Cleaning up a wave file..noise, etc
By capman21 in forum AudioReplies: 5Last Post: 12th Sep 2008, 08:55
