  1. Hey i just used dvd shrink to make dvd files to burn it to a dvdr. Now before i burned it i tested it out to see how good the quality was, and its great, just that the movie is very dark? Is there anything i can do to fix this , like use a program to edit the brigthness level or a setting? Thanks
    Oh and when using shrink, i didnt save to an image but to folderso n my hd..> Thanks again
  2. burn to a rewritable disk and check brightness in your set top player. pc viewing usually displays a darker image....
    Always check helpfiles/instructions before leaping...
  3. Yeah but when playing the original dvd it wasnt that dark..... do u think it will be fixed once its burned, or can i adjust it with some program before i burn it.
  4. Mod Neophyte redwudz's Avatar
    USA
    You could dissasemble the finished DVD file, run it through an encoder, loose quality and spend several hours trying.....Or just burn it to a RW as rcb suggested and see if it is really dark. A computer monitor is not a good way to judge the brightness level of a video file that you are going to watch on a TV.
  5. Yeah, have to agree with the what the guys said above. The resulting picture on your com screen would be darker that what appears after you have burned it on a disk and view it on a TV screen.
