Can anyone help me out here?
What I want to do (and i'm almost positive it can be done just don't know how) is record what i'm doing on my PC to VHS, i.e. playing games, stuff like that....then take what i have from VHS and record it on my PC then edit it into a movie.
I currently have a WINTV GO capture card, Athlon 1200, 256 RAM, GF2 64mb vid card. Can I use the WINTV card to send video to my VCR or should I take the card back and get a different one?
Thx in advance.
What you want to do is possible. I don't know about your particular card, you'll have to read the docs, but basically you'll need a card with dual head support. For Matrox's (like my G450eTV) there is a setting called Clone Display, which basically pumps a duplicate of your monitor out to your TV/VCR. All you gotta do is hit record.
Depending on how fast your system is (maybe you have some crazy powerful box, or a really good raid adapter) you can use a program like SnagIT to just record your computing session straight to an .avi file. (altho, I doubt this would work well for games, as they are usually pretty processor intensive, and may even use some sort of an overlay mode or something)
The second scenario would be the preferable way to go, because you wouldn't incur any of the quality loss that Computer->VHS->Computer is going to incur.
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 322Last Post: 18th Mar 2025, 14:04 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
