I recently used ATI All In wonder MMC (v7.6) to capture a VHS movie. Then I used Ulead Moviefactory 2 to create the DVD files. However near the end of the video, the audio was out of sync.
I then read the Guides from DVDRHelp.com on the ATI's MMC and ULEAD that proved helpful.
Reading the Ulead guide, it says that I have to check the properties of the video (in Ulead) and match Ulead to it. This was completed except the Audio of the video was at 44100 hz. Ulead couldn't change the frequency (Ulead at 48000hz). So it doesn't match and Ulead now wants to convert the file, which makes the audio is out of sync.
I would have re-captured the video, except the tapes already reused
My Question is can I convert the captured file from ATI that will change the frequency to 48000hz? What tools do I use?
Any answer or link to a thread that has the answer is welcome.
thanks!
MMC 7.6 only allows 44.1 kHz audio captures.
You need to download a newer version of MMC from ATI's website (they're free downloads, I recommend at least 8.1) or you can try transcoding the audio stream to 48 kHz with a program other than Ulead.
I recommend BeSweet or SoundForge.
I want to dub both audio files to the same movie but sync problem
By amdsamurai in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2011, 09:03 -
Problem with audio gradually going out of sync in ts file (captured video)
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 12:12 -
Captured video/audio progressively out of sync (on linux)
By daytooner in forum Video Streaming DownloadingReplies: 2Last Post: 26th Nov 2009, 00:26 -
Captured VHS movie and .srt subtitle not sync'd. Any way to fix?
By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 02:52 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 18:34
