I've been getting some jerky encodes in Tmpgenc recently (xvid to vcd and 1/2D1) and I think I've narrowed it down to a codec issue.
I had the xvid codec from the Mega codec pack which apparently was crap, then i switched to Koepi's but was forced to install ffdshow as well bc Tmpgenc wouldnt play ball and Procoder rendered the video upside down. So now I have both, ie the latest version of Koepi's codec and ffdshow but don't know which one I should keep, and which one will play ball with most of my programs (i.e. Tmpgenc, DVD2SVCD, Virtualdub, Procoder).
IMHO ffdshow is better, but any thoughts would be appreciated.
DF
PS: If anyone thinks that the jerky encodes (mainly during wide panning shots in the movie) are not due to a codec issue, please let me know bc this is the problem I'm trying to solveThanks.
I find some xvid clips move really jerky so what i do is load the clip into AviC (FourCC Changer) which is installed with the xvid codecs and change it to divx in both fields and apply,after that the clips plays ok.
AAC codec not working on PC ffdshow
By jack616 in forum AudioReplies: 5Last Post: 14th Oct 2011, 00:35 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 01:27 -
ffdshow codec in VirtualDub
By funky honky in forum EditingReplies: 2Last Post: 23rd Jun 2010, 12:53 -
Disabling FFDshow (from K-lite codec pack)
By mbcdc in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2008, 21:06 -
New codec integration in FFDShow
By werner77 in forum ProgrammingReplies: 0Last Post: 26th Nov 2007, 17:39
Thanks.
