I'm pretty new to ffmpegX and like a lot what I've figured out it does (I'm sure it can do much more). But, what I can't find is whether it offers automatic settings configuration based on the desired output file size, i.e. can I get ffmpegX to calculate the best seetings if I enter the number of MegaBytes I want the output file to be in the leftmost lower field? I've tried the trick but it doesn't work - all the same I just have to go through all the settings manually, and these settings always override the file size I enter. Thanks a million for any info!
nuts!!!Guest
Feedback On Intro Desired
By budwzr in forum Newbie / General discussionsReplies: 11Last Post: 23rd Dec 2011, 16:49 -
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
XMedia Recode: Can You Set the Desired File Size?
By jdanniel in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 19:07 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44
