  1. Hi all,
    I want to add hidden frames to a short clip. How can add them spread on equall intervals as example.
    Any suggestions?
    Thanks in advance.
  2. Member DVO's Avatar
    Apr 2002
    Save your short clip as animated bitmap sequance using TMPEGEncoder. You get your frames in numbered order. Remove the frames you want to remove and put your substitute with the right number as name(and as a bitmap picture). Now you can load the first picture in TmpegEncoder and it will put it all back togeder as a movie if you render it. (you might loose some quality cause of the conversions. also make sure it's a short clip since bitmaps take lot of space)
  3. Well, I want to edit a clip from 25 minutes and it tooks lots of GBs if I strippe it in pictures. And to add that all manual...
    Isn't there any program which can automaticaly add frames, let say every 10 sec as example?
    Regards
