I have some exisiting videos mostley AVI format, that i wish to convert over to a DVD format. I have TMP Author which will allow me to ready the MPEG 2 movies for DVD burning.
My problem is that I cant seem to convert any of my videos to MPEG 2 format. I am using TMPEncoder and select the MPEG 2 DVD NTSC Setting, and then I get a "MPEG 2 trial has expired" when i attempt to convert.
I dont know where to get a encoder and dont know exactly what is needed to install it. I have ADOBE PREIMERE and other video programs, wouldnt such a decoder come with these? ...
Please give me some assitance, i am dieing to get these videos to DVD, and suggestions or solutions will be thanked!
Thanks in advance.
AFAIK, no freeware mpeg-2 encoders are easily/legally available.
suggest you look at buying TMPGEnc Plus (click on the hi-lited name)... -
You can try the freeware YMPEG at the tools section. It is said to encode to mpeg1 and mpeg2 directly from VirtualDub and others.
Good Luck!
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 16:47 -
Is the feature Internet stream ready same as Wi-Fi ready on the Blu-ray DVD
By coody in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Nov 2010, 21:09 -
Simple VOBs to DVD-ready MPEG 2 HOW?
By Flarch in forum MacReplies: 8Last Post: 6th Jan 2009, 09:34 -
How to encode an Avi to dvd ready video and audio Using HCenc and Aften
By freebird73717 in forum User guidesReplies: 13Last Post: 14th Nov 2007, 15:16
