I'm havin a problem convertin an AVI file into MPEG usin TMPGEnc.
My AVI file is 480x208 and in letterbox mode as in there are 2 black gaps at the bottom and top of the movie file which I wanna keep. Whenever I try 2 convert 2 MPEG, TMPGEnc keeps the letterbox mode but puts black gaps on the left and right of the movie.
I even tried encoding in 4:3 so it fits the whole screen but same thing again. There's still a gap on the left and right although there is no gap on the top and bottom. What should I do? I have no idea what settings I should use etc.
I've tried all the Source Aspect Ratios available but I keep getting the same result. The black bars still appear on the left and right hand of the screen.
change the clip frame settings. set it to the "full-keep aspect ratio" setting.
that way, it will fit and should have the proper aspect ratio...asdf -
I've tried that and it still has a gap on the left and right of the movie. What else can you suggest?
I sorted the problem. It was jus my windows media player playin the movie with gaps on the left and right. But my realplayer was playin it real fine with no gaps on the left and right of the movie. Thus I burned it onto a VCD and it played fine on my stand alone DVD player and in PowerDVD.
Dvd safety margin
By HushNow in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 9th Jun 2010, 03:13 -
Does the lexmark x4530 support borderless printing? - margin issue
By yoda313 in forum ComputerReplies: 0Last Post: 25th Jan 2009, 19:30 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46
