I use DVD complete to author DVD's. My question is this, it states that the mpeg2 for ntsc must be 720x480 or 352x240 @ 30fps. I have a 1hr and 45 min video that I will encode with tmpeg and author. With a bitrate calculator to get the mpeg to 4gig, it says use a bitrate of around 5200 with audio set at 192. Would I notice a difference of improved quality if I set tmpeg to encode this to 352x240 with a 8000 bitrate. Seems it may look like the picture is being stretched to fit proper or will I not notice much difference and I'm just wasting time. I tried to do a search but maybe I didn't use the proper terms. Any comments are welcomed.
What was the source and what is the captured avi file resolution size ?
Always check helpfiles/instructions before leaping... -
Note that if you use the lower resolution, it often won't show up in Windows Media Player properly sized. I just created a 2hr video using 1/2 DVD quality and set my bit-rate to 4000. It plays back just fine (proper aspect ratio) in PowerDVD but Windows Media stretches it. Try your final product on a DVD player before wondering about any problems.
rcb asked
The video was captured to pc from DV at 720x480 full res .avi and exported as 720X480 full res .aviWhat was the source and what is the captured avi file resolution size ?
jg0001:
As far as it not playing proper in media player, that doesn't matter to me, It will be played mostly on a set top player. -
I would stick with 720 x 480 and process to dvd compliant mpeg usiing TMPGEnc Plus vbr 2 pass setting with mp2 audio.
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
