I convert my VHS tapes to DVD by using a RAM disc on a Panasonic E50 DVD Recorder. After the RAM disc is recorded, I put the disc into my Toshiba DVD ROM Drive and import it into Tmpgenc DVD Author. From there, I add "DVD Video" and click on the DVD_RTAV folder, author and burn the DVD. It was working flawlesly, but now when I do it I get the following error message:
The program is a mix of different video formats
The video compression format (MPEG-1 and MPEG-2), resolution, and the aspect ration (4:3 and 16:9) need to be the same within the program.
Does anyone know what this is about? I do not know why all of a sudden, I cannot import the folder into DVD Author
I saw a somewhat similar post a cuppla days ago... upshot there was that the source (satellite tv, as I remember) had changed it's signal settings during the captured time.
But, I don't know if they got the prob resolved.. sorry. You might ry an all forum search on your subj.Always check helpfiles/instructions before leaping...
Block errors in video extracted from DVD-RAM disc
By kosdi07 in forum DVD RippingReplies: 0Last Post: 2nd Mar 2012, 15:45 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
