Guys:
I am so new to this. Forgive my ignorance.
I am attempting to convert a bin/cue file to DVD and am lost. I am under the assumption that bin/cue files can eventually be converted to VIDEO_TS (.VOB) files.
Is this possible?
Better yet, is this possible on a Macintosh?
If so...please suggest some apps for me. ffmpegx is not doing the trick.
Thanks in advance for the help.
iamSINATRA
iamSINATRAGuest
Guest
try showbiz dvd first use isobuster to extract mpg movie then use showbiz to convert to vob files ,
Guestthanks for trying to help but i think he's looking for a mac solution.Originally Posted by Guest
if you are a registered user of ffmpegx you can use the "s/vcd > dvd" tool under the "Tools" section. just select the folder containing the bin file(s) and click that button
cheers
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
